Ga door naar hoofdinhoud
The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
4098 Vragen Bekijk alle
Why is my Vibration not working?
Didn't do anything to my iPhone besides using it like normal. One day, my Vibration fails to work. I tried spamming the ringer button and looked into settings. Enabling/Disabling the ringer in settings makes a weird click sound initially.
I even replaced the Vibrator in the iPhone too see if that was the problem. It wasn't. Not sure what else to do. Any help would be appreciated.
Thank You
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Try to test connection dock of the vabrator maybe it has a small shorted there or dirt if it not work try to the replace new one part
Was dit antwoord nuttig?
Score 1
Commentaar:
OP: Also good thing to check continuity of the vibrator connector points to the ribbon connector pins via a digital multimeter if you have one on the logic board. Should beep to indicate that there is no broken connection between them.
door
Voeg je antwoord toe
Sleetui zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 228
