oven not heating enough
my oven turns on and heats for about 4 minutes then shuts off??
Is dit een goede vraag?
If its an electric i can say this is a thermal fuse problem. Usually the one on top of the oven basket. These are round fuses and can be checked by connecting a continuity tester on it and placing it on the stove. Have a thermostat on there too. The heat should match the rating and it will then disconnect the current when it reaches its designed temperature. These are cheap to replace and will be the best bet.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 76
jclaire, help ifixit help you, by supplying more info. make model #, gas or electric, this way your question may be able to be answered more effectively. Good luck.
door L Pfaff
