Ga door naar hoofdinhoud
2.3L 4cyl or 3.0L V6, 6th Generation
426 Vragen Bekijk alle
Dashboard HAZARD LIGHT is out.
How do I replace the tiny light bulb for the HAZARD LIGHT SWITCH on the dashboard? I know how to replace the bulb for the clock on the dashboard but how do I replace the bulb in the button on the dashboard that is used to turn on the HAZARD LIGHTS?
Thanks again.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
@mconley ,I believe I posted how you were to change the clock bulb. From that video, remove the hazzard button / take it apart and change the bulb. Be adventurous, You can do it. Check the vids may help. Good luck.
https://www.youtube.com/watch?v=gjSLqpHF...
https://www.youtube.com/watch?v=P3TqheRs...
https://www.youtube.com/watch?v=MyjDCdK-...
Was dit antwoord nuttig?
Score 1
Check out this YouTube video
https://youtu.be/MyjDCdK-kjo
Update (12/13/2016)
Okay, sorry about the clock video.
I checked out this website and got a diagram for replacing the light to the hazard switch.
http://www.hondapartsnow.com/parts-list/...
It looks like there are 2 types of bulbs depending on the part you have (Part 11). You will have to take a look. Hope this helps!
That should work for the CLOCK but NOT the HAZARD LIGHT (the triangle shaped red light on the dash to the left of the clock.
Thanks anyway.
Voeg je antwoord toe
Michael Conley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 1,396
