Ga door naar hoofdinhoud
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4809 Vragen Bekijk alle
issues after screen and battery replacement
Hello,
I recently replaced the screen, battery and lightning port on an iphone 6, it was working and charging fine for a day or 2 then it stopped powering on. The computer recognizes when I plug it in...
Is dit een goede vraag?
Een opmerking toevoegen
PC Laptop batterijen
An easy fix for a big power boost.
Nu winkelen
Nu winkelen
2 Antwoorden
Het nuttigste antwoord
Could be a bad battery. I would put the old one back in just to test it. If that's not the issue, it could be a charging port issue. If neither of those are the problem, it could be a more serious issue.
Was dit antwoord nuttig?
Score 1
Commentaar:
I tried a diff battery and screen. I'm afraid you might be right.
door
I've done some more reading and people seem to think it's a logic board issue
door
If iTunes recongnizes it could've blown a backlight filter or shorted the backlight line. This happens a lot with aftermarket screens on the iPhone 6 and 6s. Does it look dim (can you see a dim apple logo when it boots up) or no backlight at all?
Score 1
Commentaar:
Just curious, does using a phone flashlight help with seeing the dim apple logo on a backlight issue iPhone?
door
All replacement parts came from ifixit.
door
Also to add in there is a chance of it blowing when you plug in the screen connectors with the battery still plugged in.
door
Voeg je antwoord toe
Jesse Seguin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 77
