Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Wii Remote is de originele, primaire controller voor de Nintendo Wii spelconsole, uitgebracht op 19 november 2006. Het modelnummer voor de originele Wii Remote is RVL-003.
Can't get Wii Remote to turn on, even with new batteries
My Nintendo Wii Remote will not turn on even with new batteries. It blinks but turns right back off.
Is dit een goede vraag?
Score 7
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
If your Nintendo Wii Remote will not turn on, use this Nintendo Wii Remote Won’t Turn On problem page for possible causes and solutions.
My best suggestion would be to open the controller up and inspect for any corrosion or water damage. From the sounds of it, this is probably the case. If the inspection doesn't come up with any leads then the only other suggestion I could make is replacing it with a used one off eBay. They're very cheap now and it's the most economical move to save time and/or money.
Good luck.
Was dit antwoord nuttig?
Score 1
I've had my Wii remotes since the Wii first came out and have had this problem with all of my remotes, its usually because the battery contacts have worn out over time. The best fix is to spray some contact cleaner on the battery contacts, rubbing alcohol also works, if its visibly corroded you can use some sandpaper and just scrape it a little bit.
You might have to re solder the battery joints to the Wii mote, thats what happened to my Wii mote.
Voeg je antwoord toe
number1nana zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 135
Altijd: 20,617
