Ga door naar hoofdinhoud
Won't see battery after teardown
2.16 GHz
Machine was overheating and shutting down after running for 15 minutes. I tore it down, cleaned the vents, reapplied thermal paste, replaced the optical drive. Updated from 10.6.2 to 10.6.4, installed iLife "11, Norton "11 and did all updates. Machine now runs (4 hours with no heat problem). Optical drive from G5 iMac works fine. Problem is that it won't see the battery. Battery has a 90% charge and boots on another MBP just fine. Good battery from other MBP does not show. Coconut battery does not show battery. Did I miss connecting something on the logic board?
Zapped pram to no avail
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Reseated battery connecter to logic board. The original seating looked good. Problem fixed.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
good followthru +
door
Voeg je antwoord toe
mayer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 1,125
