Ga door naar hoofdinhoud
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
71 Vragen Bekijk alle
Damage to touch - display loose
I believe my laptop may have been stood on and the right hand side of the display is loose, causing it to switch off continually. Do I need to replace the whole screen or can it be fixed? A new screen is expensive and mine isnt actually damaged, just loose.
Many thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Here is a link to the service manual for a Dell XPS 13 laptop.
In it you will find the pre-requisites and procedures necessary to remove/replace the display. By using this you can open your laptop and see what is the cause of your problem and possibly how to fix it.
http://topics-cdn.dell.com/pdf/xps-13-93...
Hopefully this is of some help
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
lisa kater zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 187
