Ga door naar hoofdinhoud
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Vragen Bekijk alle
Screen won't turn on after cpu upgrade
I just upgraded my late 2015 imac's cpu to an intel core i7 6700k skylake unlocked 4.0Ghz processor and when i tried to turn it on after, i got the chime that it turned on, but the screen will not turn on . I checked the connections and they're all good, so i have no idea what it could be . Anyone have an idea? Thanks
Is dit een goede vraag?
Score 1
4 opmerkingen:
I followed ifixits procedure step by step. And the fan works as well as key noises but the screen wont turn on...
door
Also tried resetting pram and smc..no luck
door
Switched back to my old cpu....no luck wtf
door
Sooo i just found out that its all working good...except the screens light is dead. If i shine a flashlight on it i can see everything...wtf how can i fix that? Replacing a 5k screen is probably $$$$$
door
Voeg een opmerking toe
1 Antwoord
Did you fix it? Are the led’s on the LB on?
Was dit antwoord nuttig?
Voeg je antwoord toe
Sean H zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 175
