Released September 25, 2015. Model A1687/A1634. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
672 Vragen Bekijk alle
Facetime camera and Earpiece not working.
Hi all looking for some advice. I recently replaced the screen on iPhone 6S Plus. Now the Facetime camera and ear piece don't work. The front facing camera and flash light work. I can also still record video and sounds. Any help much appreciated.
Update (11/27/2016)
Checked the connection it clicks into place every time. I tried the ear peace through Siri which now works should if tried it in the first place. So it's just the camera nit functioning now. Thanks for the advice so far. This is my first repair.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
3 Antwoorden
Gekozen oplossing
You probably made a mistake when re-connecting the FPC connectors from the screen. The connector for the camera needs to be properly seated on the logic board for it to work. They are very delicate and can be easily damaged in you are not careful.
Look carefully at steps 17 & 18 from this guide.
iPhone 6s Plus Screen Replacement
Was dit antwoord nuttig?
Score 3
You can even use the Facetime app on your Windows PC without any hassles if you have a PC or a laptop. It works just fine. You can go through Facetime for PC and learn how to use it on your PC or laptop with ease.
Thanks guys it was the cable, a quick replacement all works fine now.
Voeg je antwoord toe
jamieflint zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 2
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 10
Altijd: 371
