Ga door naar hoofdinhoud
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 Vragen Bekijk alle
How can I reset Parental Controls
I forgot the pin and the secret question. I tried calling them, but they said that the service was no longer available. WHAT DO I DO?
Is dit een goede vraag?
Score 10
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
kdcao1 , 3 links below will take you through the process of resetting parental control if you have forgotten pin. and secret question. Good luck.
http://en-americas-support.nintendo.com/...
https://www.youtube.com/watch?v=_uvW3LZc...
http://xerohournix.blogspot.ca/2013/01/r...
Was dit antwoord nuttig?
Score 19
9 opmerkingen:
Thanks, the last one helped the most.
door
The last link was the best one, helped me reset a second-hand DSi easily. Thank you so much!!
door
Same, the last one was the one! Thank u so much!
Edit: I used this for a dsi xl and it was quick and easy.
door
Tried only the last one & it worked thnk U
door
the last link worked on my DSI XL
door
4 commentaren meer tonen
THIS TOTALLY WORKS :'D It saved my boyfriend and I so much time. It worked with a DSi that he bought from a third party seller. This really helped out! Would recommend to someone else
I followed the comments and went right to the third link! I was confused at first because you need to set the DSi's date to the current date
Score 1
The last one helped thank you
Voeg je antwoord toe
kdcao1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 143
Afgelopen 30 dagen: 636
Altijd: 43,674
