The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3790 Vragen Bekijk alle
Screw length and placement
Please help
I want to build an iPhone 5s from scratch but I need to know exactly where each screw goes with it's length
PLEASE PLEASE SOMEONE help
I have seen this guide before but can't find it again
If someone could link it that would be great thanks
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
3 Antwoorden
Gekozen oplossing
If you follow this guide iPhone 5s Logic Board Replacement then you will see where each screw goes and what dimension it is.
Was dit antwoord nuttig?
Score 3
Commentaar:
Thanks so much
Any advice for the rest of the phone?
door
There are various guides if you start your search here...
iPhone 5s Repair
door
Yeah but like I said I need one with all screw lengths if possible
door
As far as I know, there is no one guide that shows all the screw lengths. Maybe someone else here can chime in. Otherwise, go through the guides as you need them. If you are only swapping a logic board from one good housing to another, that should be pretty straight forward. If you are building up a blank housing from scratch, start with the button flexes and mark the screws before you move them. If you have a jumble of parts and screws, then go through the guides.
door
Its all good I just realised if I follow the housing replacement it has all the screws so thank you very much
door
1 commentaar meer tonen
Oh my god. I wanted to do this to. But I hate to break it to you: IT IS NOT WORTH IT.
save up money, and buy a new one.
The components are retail-priced, so if you bought all the components, it would cost you more than just buying one. And touch id won't work, until someone finds a way to re-pair it.
Score 2
Commentaar:
Yeah but I bought a 32 gb motherboard
And with all parts totals to only about £70-£80 so I'm going to continue trying
door
then you better assemble it right. You must also get a 3rd party rear chassis without the imei of your phone etched into it, and then etch it in yourself.
then you must put in all the adhesives apple uses (which can be very hard to come by), you must apply threadlocker to some (but not all) the screws, then you must put the thing together. THEN you must go to apple and have them service the touch id module, crossing your fingers you did a %#*@ good job putting this all together, so they wont spite you for a 3rd party repair. IT IS NOT WORTH IT!!! You'll waste too much of you're valuable time with this.
door
Well here is an ifixit guide to disassembling the phone, so in reverse order you'll have a franken-5s
iPhone 5s Teardown
Voeg je antwoord toe
Ryan Green zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 8
Afgelopen 30 Dagen: 35
Altijd: 516
