Ga door naar hoofdinhoud
My Sanyo DP55360 TV won't work
The led light comes on then shuts off it will do this three times that I turn it on then just quits. The screen stays off. What do I do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi! Joel
Maybe the Power Supply Board is broken this happens by electricity fluctuations and other things like damaged or expired capacitors you can search in the WEB with these symptoms to be more convinced. You can fix by yourself replacing the Power supply board with a new or used one. Search in Ebay with the correct model and part number before you buying, Always is advisable to disassemble the TV to see how it the board and to look for the serial number of the piece. Do this first will not cause you future headaches with the incorrect part... Good Luck!!!
Was dit antwoord nuttig?
Voeg je antwoord toe
Joel dunn zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 150
