Ga door naar hoofdinhoud
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Vragen Bekijk alle
MacBook Pro won't turn on, CPU gets really hot. But fans spin
Hi there! I hope you guys could help me determine what's wrong with my MacBook Pro.
tl;dr If I press the power button, the MacBook Pro won't turn on at all: no startup chime and apple logo, keyboard light and caps lock do not light up. The battery would charge, indicator turns from red to green when full. Nothing on screen. The area where the processor/heatsink is located gets really hot really quickly. The only things that look like they work are the fans, which start spinning as soon as the power button is pressed and they get louder as the heatsink gets hotter. Resetting NVRAM/SMC did not work. Do you think the logic board is dead?
Long story:
5 days ago, the MacBook Pro was last used for general work at the office while being charged. After work, I closed the lid, put the MacBook Pro in my bag and drove back home. En route, the bag fell down from the car seat during a sharp turn and I remember thinking oh crap my macbook is inside but I forgot to check it out as soon as I got back.
It was around 12 hours later that I opened the MacBook Pro and noticed it would not wake up as usual from sleep. Tried pressing the keyboard, brightness key and power button and it did not work. Tried a hard shut down and boot up again. Did not work. I figured it might be running out of juice, so I closed the lid and put it back in the bag.
The MacBook Pro stayed in the bag for around 1 hour until I took it out again and was shocked to find out it was getting really hot. Like dangerously hot. The lid was still closed, the fans were blowing like crazy and the whole thing was burning. I opened the lid, tried to cool it down and the fans stopped blowing when I attempted a hard shut down.
After it cooled down for a few hours, I plugged it in to a charger. It charged normally and the indicator turned green after a few hours. I turned the MacBook Pro on. It won't turn on. The area where the heatsink is located got hot really quickly. I could hear the fans blowing gently and they got louder as it got hotter. Tried closing the lid but the fans would not stop blowing and the heatsink just got hotter so I turned it off by pressing the power button for a few seconds until I could hear the fans stopped. I have also tried resetting the NVRAM and SMC as many have advised but they did not work.
And this is where I am now. Tried opening the lower case but could not see anything wrong; nothing burnt or out of place. There was quite an amount of dust building up on the board which I tried to clean a bit but it still won't turn on. My main concern is the data on the SSD which I don't have any up-to-date backup of. I was thinking of getting an OWC Envoy Pro, hoping the SSD is fine before attempting any kind of repair.
Based on the symptoms, what do you guys think the problem might be? Is there anything I could try before sending it for repair?
Thanks in advance and any help is appreciated!
Is dit een goede vraag?
Score 3
4 opmerkingen
I’m having the exact same issue. Did you manage to fix the it on your own? Would love to know what steps you took if you did. My country doesn’t have an Apple store to take it to. Any help would be appreciated.
door
@Joan Clarke hey there, I ended up taking it to an Apple Store and have it checked. If I remember correctly they said there was a problem with the logic board and that it needed to be replaced. It cost me around 500 USD. If there is no Apple Store in your country, try searching for Apple Authorised Repair Provider in your area. Good luck!
door
Just an update on this (5 yrs later lol) in case anyone has a similar issue and stumble upon this post.. hope this helps!
I ended up taking my MBP to an Apple Store in Tokyo during a trip and have it checked. If I remember correctly they said there was a problem with the logic board and that it needed to be replaced. It cost me 60,000 JPY / around $500 and took less than a week.
Still works great to this day for daily use and in fact I’m using it now to post this :-D
door
@irvan thank you for your response. I appreciate it
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Take it in and have it checked for this free repair. I would not say anything about the drop.
https://www.apple.com/support/macbookpro...
Was dit antwoord nuttig?
Score 3
Het nuttigste antwoord
Something clearly got dislodged in the fall. Without making a detailed inspection it's anyone's guess here on what is damaged and what would need replacing.
I would recommend going to an Apple Store or Apple Authorized Service Center to have them do an estimate. At least find out what's wrong and then tell us :-)
Maybe we can guide you on fixing it your self.
Score 3
Hi there, I know it's been a while but did you solved your problem? What happened? I have the same issue.
regards
Score 2
1 Opmerking:
Hello, did you find out what was wrong with your laptop? I am having the exact same issue
door
wow i had this issue, well sort of. though my MacBook did eventually turn on again. using it now.
I powered my macbook down, then tried to turn it back on a few hours later, but it wouldn't turn on, the macbook was warm underneath. it had not been charging before hand, and battery was around 70% charged. just unusual, first time its happened. was about to take the underside off, so i could unhook the battery, and then rehook the battery, you could try that. but for me, i didn't need to, though would like to know what has gone on.
Score 1
Voeg je antwoord toe
Irvan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 30
Altijd: 24,038
