Ga door naar hoofdinhoud
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
169 Vragen Bekijk alle
Why no power unless charging?
Hi. Can anyone confirm the issue. My Ipod Nano 6th Gen only powers on when connected to the charger. As soon as the charger is unplugged the screen turns off and is unresponsive until the charger is reconnected. My suspicion is a dead battery, but could do with a second opinion.
Many thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes sounds like a dead battery, they are usually not that expensive so I would recommend ordering one. Be careful when taking the screen off, it is easy to chip/crack
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
I agree with Reece. Replacing the battery should surely fix your issue. When removing the device from the charger causes it to power off instantly, it is a very strong indication of a failing battery. This applies to many different devices too.
door
Excellent. Confirmed my suspicions. Thanks for your help
door
Voeg je antwoord toe
Bigphilly71 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 103
Altijd: 2,852
