Ga door naar hoofdinhoud
The Hott T725-8G is a 7-inch Dual Core 5-point touch screen Android tablet.
Why is my tablet loading slowly and freezing?
After using my tablet for a bit, it continuously gets slower and begins to freeze. I've made sure to clear any apps that I'm not using, but it continues to freeze. Is there anything I can do to fix this?
Is dit een goede vraag?
Score 3
1 Opmerking
Student Question
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If the device is moving slower or freezing you might need more RAM. Use the RAM replacement guide to add more RAM to your computer. Another option to try is a soft reset. When you turn off the power then turn the tablet back on. It also could be a software problem where you need to reset the tablet to factory data, but this will erase all internal storage.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
How to fix it or repair? Is there any option to help me? Is it OK to repair now using this network?
door
Voeg je antwoord toe
Emma Carroll zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 116
