Ga door naar hoofdinhoud
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
151 Vragen Bekijk alle
Completely unresponsive a must read
Hello I have (2) iPad 2 with the exact same problem..I believe. Both of them, will not turn on or charge..but i know all the components work...because I've tested them
I have a 3rd iPad I have that works that I test everything on..
So on my 2 broken ...they both have working battery's..and working lcd..being a little new to iPad repair I can clearly see a few differences..but these iPads are the same model. I'm not sure what each is missing..or why has some motherboard chips but not the other? I wondering if I can Doctor the two iPads to make 1 working one..but am confused about 1 significant ribbon cord one has...and the other isn't designed for it..I will attach pictures...you guys are awesome!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
The different cords are because there were 2 style iPad 2 wifi. I snapped a picture of 2 empty iPad 2 cases, both A1395. One is what I call an iPad 2.5 since they did change the innards.
You can interchange parts on them without a problem. Its a pain taking the top apart though, which is what connects your buttons and camera to the board.
When you say you know all the parts work, how did you test that? You say you have another iPad 2, what happens if you connect one of these boards to the 3rd one?
Was dit antwoord nuttig?
1 Opmerking:
When I try them on the working iPad they work. I'm not sure if I need to replace both the motherboards and see if that just does it? Or if there is a simpler way..or cheaper
door
Voeg je antwoord toe
Brittany zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 114
