Laptop keeps rebooting at startscreen its stuck in a reboot loop
Hello,
I work at a pawnshop and repair laptops now we got in this Samsung Ultrabook 5 Series. And i got this weird problem going on.:
The laptop keeps rebooting at startup. I cannot enter the recovery state (F4) but i can access the bios (F2). I have tried everything but nothing works.
The weird part is that when i choose in the BIOS to boot trough a UBS with windows 7 it boots the USB and installs windows fine :S As soon as i remove the USB and ask the laptop to startup from HD it keeps rebooting again. But if i put the USB back in and don't push a button to access startup it boots back to WIN7 :S
I have installed another HDD, Replaced the battery. changed RAM. In windows did an error check but there is nothing wrong with it!!!! I Updated the BIOS, removed battery and pressed the "power on" for 1 minute.. nothing seems to work.
Thanks in advanced for the help.
Best Regards
Stefan
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Commentaar:
Hi, How far does it get into startup before it reboots?
door
Samsung Splash screen with the options BIOS (F2) or recovery (F4) then it loads the bar on left corner and powers off and reboots. When i press F4 it says please wait but then just reboots. But on F2 i can enter the bios where i tried all different options.
door
how u may sum sung laptop whan i restart the windows shows boot manager whats wong
door
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
3 Antwoorden
Gekozen oplossing
Hi,
Here is a link which may help you to resolve your problem.
http://support-us.samsung.com/cyber/popu...
There is also this which is a follow up if you don't succeed with the first link.
http://superuser.com/questions/510311/tr...
Was dit antwoord nuttig?
Score 2
Commentaar:
I don't have the option "Secure Boot" i am on BIOS "P15AAJ" the laptop came standard with win 7.
Again by putting a USB Stick in the system it will go past boot trying to boot from the USB but if i ignore the boot from USB it will go trough and start windows 7 normally.. :S
door
Hi, Is the HDD being detected without the USB inserted? Go into BIOS and see if it is being shown on start up.
door
Hi, Also found a thread where they said that installing from USB creates problems. Apparently there are no such problems if you install from an external DVD drive http://forum.notebookreview.com/threads/...
door
I am thinking there mite be a hidden partition on the motherboard somewhere of 20 gb. It cant be in the replaced hdd since i put a new one in. i have cleaned it with diskpart and installing win 7 on there. will update!
Score 1
Commentaar:
No success.. :(
door
Hi, Did you try installing with an external DVD drive, if you have one that is?
door
Yes tried, i am now so far that instead rebooting i get some menu where i have to choose my boot device :S And only the HDD is selected (Windows 7 is installed on this) When i press enter i keep getting the same menu. It whont boot from the disk. However if i use the thumbdrive to go past boot it works again :S Now trying to install windows 10 pro just to see if. It looks to me there is an error while booting up is there anyway i can change how the computers boots up? and just remove a command-line or something :S :S: S :S :S
door
Hi, This link mentions something about an iSSD express cache where the boot files are stored. http://forum.notebookreview.com/threads/...
Hopefully it will give you some clues. It seems a lot of people have troubles with Samsung Ultrabooks and installing OS.
door
Thanks jayeff! I think the problem may lay in the fact that this laptop has a iSSD and some how this causes the boot problem.. :S
door
4 commentaren meer tonen
I found a solution and i am trying this: (But as soon as i try to copy with bcdboot it says error copy file)
First, some background. This laptop comes with a 1TB HDD and an 8GB iSSD, which is used as a cache to speed up Windows and apps. Samsung uses Diskeeper's ExpressCache software for that purpose. This SSD causes a rather large problem to the Windows installer. For whatever reason, Windows refuses to install its "System Reserved" partition on the HDD, downright refusing to proceed with the installation if the SSD is already partitioned for ExpressCache. But, repartioning the SSD and just letting Windows install itself, doesn't make things easier. In fact, it causes major troubles. It appears that the BIOS really doesn't want to boot off the SSD, which is where Windows decided to install its boot partition. So, here's the thing- how to get the HDD into a state where both Windows and Samsung's BIOS were happy, and the SSD free for ExpressCache use.
Before installing Windows and things to keep in mind
For your convenience, you might need to print this guide and read once before proceeding.
Backup your drivers to an External Flash Drive or DVD, using Samsung Recovery Solution. (Bear in mind that you don't have any network connection after a clean install and neither a backup partition at your pc)
Make sure your BIOS are set to boot from DVD or USB Drive, by changing priority. If you choose to use a USB, you have to disable "Fast BIOS Boot" as well.
In case of using a bootable USB for the installation, a message might emerge, implying that drivers are not installed and cannot proceed further. Just click "Cancel". Then, you will be brought back to the welcome screen. At that moment, remove the USB drive and plug it back in, to a different USB port this time. Click "Install Now" again. The installation should proceed as usual.
Installing Windows
Insert the istallation media on your laptop.
At the Windows Setup Wizard, select "Custom Install" to view all disks.
At the "Advanced" option, choose to format all disks and delete the SSD.
Press "Shift+F10" to launch cmd. Otherwise, reboot into the Windows Setup wizard and choose the "Repair" option, in the bottom left corner, and in the tools menu choose cmd.
Type in diskpart to get into the partition tool.
Use the commands list disk and list part to determine which disk is what (check size parameters). For me, Disk 0 was the HDD and Disk 1 was the SSD. The following instructions assume this.
Select the HDD: sel disk 0
Delete all partitions on it: clean
Create a 100MB partition for Windows 7 (or 350MB for Windows 8): create part primary size=100 (or size=350)
Format it: format fs=ntfs quick
Assign it a letter: assign letter=f (if F: is in use, pick another one. Use the list vol command to see all volumes and their letters)
Create a partition that fills the rest of the disk: create part primary
Format the large partition: format fs=ntfs quick
Assign it the letter C: assign letter=c
Exit both Diskpart and cmd.
Reboot back to Windows Setup Wizard to install Windows into the large partition that was just created. !!CAUTION!! When Windows restarts your machine to complete the installation, do NOT change priority at the BIOS menu as usual, but instead boot from the installation media, once more, and choose the "Custom Install" option.
There is a great chance that Windows installed its System Reserved partition on the SSD, so choose the "Advanced" option and delete the SSD. Launch cmd (Shift+F10) and type diskpart.
Use the commands list vol and assign to ensure that both the system (F:) and the boot partition (C:) still have drive letters.
Select the system partition (sel vol f) and mark it as active: active
Exit diskpart and at cmd type the command: bcdboot c:\windows /s f:
Reboot and you're good to go.
After the installation
The easiest way to have Samsung's Easy Settings and ExpressCache installed to your machine is through the backup created by Samsung Recovery Solution, since you don't have an internet connection after the clean install. (Even when you get to have one, do not connect during this proccess (because of Windows Update interference) and wait till it finishes)
Browse the DVD or External USB Drive to find the "SystemSoftware" file and launch the "SecSWMgrGuide.exe".
Install "Easy Software Manager".
Install everything from the "Drivers" tab.
From the "Miscellaneous" tab, install "Windows 7 SP1 Critical Updates" and "Windows 7 SP1 common patches".
From the "Utility" tab, install "Easy Settings" and ExpressCache".
Finally, choose any other software you might need.
You are ready to connect the internet and install Windows Updates.
In case you didn't backup your drivers using Samsung Recovery Solution, you need to manually download and install these drivers from the Samsung's website.
To find out if ExpressCache is working, run cmd as administrator and type ECCmd -INFO. If it's marked as mounted and gives you the application's information then you're fine.
Score 1
Commentaar:
This method worked! Thanks so much.
door
Epic Solution. Works perfect. 04-03-2019. Thanks !!!
door
I have this same issue also i try this method no solution
door
Give me the solution anybody knows
door
Voeg je antwoord toe
sjmmimpen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 17
Afgelopen 7 Dagen: 124
Afgelopen 30 Dagen: 704
Altijd: 21,090
