Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Vragen Bekijk alle
Why is only one "wet indikator" red
I just fixes an iPhone 5s which wasn' charging and didn't respons to DFU reset. Turns out, a new battery did the trick.
But here is whist pusseled me: The guy who sold it swore that it wasn't water damaged,
The water indikator by the ear speaker and sim tray was bright white, but the one by the battery was red. Seems impossible.
Can anyone explain?
Bjop
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It is possible, water didn't go all the way trough the iPhone...often situation in servicing business. If everything else is ok, don't bother, carry on with usage...
Was dit antwoord nuttig?
1 Opmerking:
But weird though, water in the middel of the phone. I was thinking condensed water maybe.
Anyway, looks ok. Screen looks great, god response and finger print Trads perfekt. Ill run it for a couple of days to see if battery drains.
Thx
door
Het nuttigste antwoord
It is most likely not water damage to the entire logic board. Probably a small amount of water from rain, or another source got into the phone. Since the water damage indicator near the battery was red, the water probably got into battery connector. This would short the pins in the connector causing rapid power cycling ultimately killing the battery. Even though replacing the battery, in this case, would fix the problem, I would recommend inspecting the logic board for any other corrosion before continuing use. Doing this will ensure you don't have any issues further down the road.
Score 1
Voeg je antwoord toe
Bjorn Stokke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 58
