Ga door naar hoofdinhoud
laptop gets power but doesn't start
Hello everyone
So I need your help with my msi ge 60
since about a month and half my laptop has been through cycles of working fine for 10days(ish) then stop working for other 10days then start working again then stop..
i initially thought that it gets no power, but i discovered that the battery led still works
but when i press the power button nothing happens, no power led, no fan spinning no nothing.
does anybody know what this might come from?
edit : i took the laptop apart to clean it with contact cleaner and to check if something is burnt or rusted and nothing visible. also when it works, it works, fine no strange noise, no overheat just fine. but still right now it's been 10 days since it worked last
thanks for your time
Is dit een goede vraag?
1 Opmerking:
so does anybody have a clue please
door
Voeg een opmerking toe
2 Antwoorden
Contact cleaner could have caused issues, make sure that your laptops power flex and power button are attached to your motherboard.
Was dit antwoord nuttig?
no the issue was way before i used the contact cleaner, also i made sure i connect the flex correctly
Voeg je antwoord toe
salem zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 256
