Ga door naar hoofdinhoud
The Pandigital novel reader is a tablet meant for reading books, browsing the web, and listening to audio. Model number: PRD07T10WWH7.
Why won't my device start up?
Hi,
I recently got my device and it's been working fine but last night I tried installing an SD card and after telling me to please wait it turned off and won't start back up, any ideas on how to fix it?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
This could be caused by a few different things. Make sure the device has enough charge to power on. If the device is charged and the issue still persists, it could be a faulty power switch. This can be fixed by replacing the power switch.
Another cause could be the battery. The capacity of the battery is reduced after each charge cycle. This is a fairly old device and it is possible that the battery is no longer functional. You may need to replace the battery.
Finally, this issue could just be a result of the display not turning on. If this is the case, you will need to replace the device's display.
Pandigital Novel PRD07T10WWH7 Troubleshooting
Was dit antwoord nuttig?
Score 1
1 Opmerking:
what if when you try to charge it, it automaticly turns on? also has the same problem after it auto turns on
door
I'm having somewhat of the same problem, like the other person said, probably something to do with the sd card, shot in the dark here, but try taking it out and letting the battery die, might just work
Voeg je antwoord toe
Aaron Jesus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 1,516
