Why does my tablet lose charge so fast?
I charge my device to full every time, yet it loses all of its charge in less than two hours of reading. What can I do to fix this? What could be the problem here?
Is dit een goede vraag?
This could be caused by several problems and the issue could either be with the battery, charger, or simply how many programs you running. If you are using bluetooth or wifi in the background and do not need them try turning those off. Also if you have your screen brightness turned up high try lowering that as well because it could be draining extra battery. Lastly try and close any background applications that you don't need to be running.
If you have tried this and still have a problem then it could be a problem with the charger or battery. I recommend using the official charging cable if you aren't already and if you have a spare try charging with that cable.
As a last resort the problem could be that your battery isn't working properly and will have to be replaced. Avoid overcharging the device and also try not to let the battery life drop all the way down before recharging. It is optimal to keep the battery life at 60-80%. Try that for a couple of days and if you still have trouble then the battery most likely needs to be replaced.
Was dit antwoord nuttig?
My little sisters table is doing this so ty from this information I will try it
If your WIFI is on the battery runs down faster. If your not using WIFI to read turn it off.
Yes. It does help.
i have a problem with my Onn. tablet
i was just playing a minecraft ripoff on it (that's not the point)
anyways i was only playing with it for a few minutes and my tablet shut down and it's battery was only at 80%
and i tried playing again and somehow the battery went from 80% to 14% in a few seconds
if i replace the battery,
do all of my games start over and i have to install them again?
@appleiocation78 no, it shouldn't be any different from turning the tablet off
that's not what i meant
if i replace my battery
does my games start over?
3 days ago by darth mango
i have no idea what that means :(
How long does my onn tablet charge
I have an onn tablet the battery goes from 100% to 1% in about 5min. It says hot remove battery which don't cause it's a tablet. I installed apps to cool down doesn't work
If your tablet last for 2 day battery life, It means you take care of it well.
i have an onn table but its battery goes from 100% to 15% to dead in 3 mins .the battery still drops whens it off.
I'm having this issue too
Like not dropping your tablet or phone. If you drop it a lot, it will reduce and damage the battery.
I want to know if my fire tablet wont charge if it has too many games on it that it won't keep charging
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 55
Afgelopen 30 dagen: 226
Altijd: 18,161
1 Opmerking
now my onn. tablet
shuts down a few seconds after i turn it on
and it's at 93% or charge
door AppleIocation78
