Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
iPhone se won't turn on
I bought an iPhone se from someone online because it didn't turn on. I was guessing it might just be a bad battery or something. When I got it I found out it was bent. I plugged it in to the computer and it wasn't recognized. Nothing shows up on the screen when you hold down the home and power while plugged in. I'm not sure how to test for a bad battery but I'm not sure if that's the problem I'm thinking it might be something with the bend. Any ideas on what it could be?
Is dit een goede vraag?
1 Opmerking:
Could this be a possible water damaged phone?
door
Voeg een opmerking toe
1 Antwoord
Take it out of the housing. See if the board is bent. Hopefully it is not. Put it in a new housing and replace anything that is bent. If the logic is bent, EXTREMELY CAREFULLY, VERY SLOWLY, try to bend it back so it is even. Be EXTREMLY gentle with it. See if it fires up then. Also see if it works with no housing.
Was dit antwoord nuttig?
1 Opmerking:
Tried this and it was slightly bent so I very gently bent it back really close to straight but Not 100% but still nothing
door
Voeg je antwoord toe
Gabriel Huerta zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 477
