Ga door naar hoofdinhoud
Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
1574 Vragen Bekijk alle
Touch IC or connector or both?
Got a 6 plus that is like this, does it need new touch ic or connector?
touch is bad so that needs doing and grey bars at top
the screen is fine, i just want to make sure the phone will display fine if touch IC is fixed
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If you're getting grey bars at the top 100% touch ic guaranteed. I also noticed your top right backlight is dim. If it's still this way after swapping the touch ic you need to replace part of the backlight circuit as well.
Was dit antwoord nuttig?
Score 1
Commentaar:
that's what im talking about
door
You know on the top right that is usually either LCD connector on logic board or LCD ribbon cable needs to be pushed in more.
door
it can happen in either corner i have it on a 6 but not sure if it is, it only happened on the 6 because i test screens constantly so it got damaged. the connector looks fine to me
door
Voeg je antwoord toe
David F zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 114
