Ga door naar hoofdinhoud
The Nikon 1 AW 1 is a waterproof camera manufactured in 2013. This camera is Wi-Fi capable and records in 1080p with a 14.2 MP lens.
Why did it stop working after a swim in shallow water?
I went swimming in my 6 ft pool and after taking a few pictures, it stopped working all of a sudden. It says that it's waterproof up to 15 meters so this shouldn't have been a problem for it.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Did you make sure that your lens was secured tightly to your camera? Is it not turning on at all? I would refer to the troubleshooting page to see some quick solutions that might solve your problem. Apparently this is a common problem with this specific camera, however, if the camera is not turning on at all, I placed it in a bag of rice for a few days, then gently blow dried the camera and it turned back on! Hopefully this helps and I wasn't entirely lucky. Good luck bro!
Was dit antwoord nuttig?
The O-rings need to greased (first cleaned), before each use, like those around the battery door, and the lens mount, or the risk for water ingress is huge!
Voeg je antwoord toe
Daniel Heshmaty zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 299
