What replacement Hard Drive do I need on 27" iMac
What hard drive do I need to replace a seagate ST31000322CS that is failing in my late 2009 27" iMac, I would like to replace like for like.
Philip
Is dit een goede vraag?
Philip
If you decide to replace the drive, I would go with a Seagate SSHD 1 or 2 TB. This will give you a dramatic perceived speed increase.
You may have temperature sensor visor and run away fan if your original drive is other than a seagate. You will need (at minimum) Apple part # 922-9216 to prevent it. At most the OWC OWC In-line Digital Thermal Sensor for iMac 2009-2010 Hard Drive Upgrade https://eshop.macsales.com/item/OWC/DIDI...
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 39
