Why does my turn signal oonly work on one side?
Turn signal works normal on left side, but it blinks rapidly on right side and only the front light blinks.
Is dit een goede vraag?
Hi Dennis,
A rapidly blinking turn signal often means that the light bulb is about to burn out. Try replacing the bulbs and see if that fixes your problem. This video might help with the replacement: https://www.youtube.com/watch?v=c0Rk3kh2...
Good luck,
Paige
Was dit antwoord nuttig?
You need a new Turn Signal Switch, relatively cheap part
Bulb replacement solved the problem
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 121
1 Opmerking
Bulb replacement worked. Thank you
door Dennis Johnson
