Ga door naar hoofdinhoud
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
111 Vragen Bekijk alle
iMac won't power on. How do I check this model's power supply?
My iMac won't power on at all and I suspect the power supply is the issue. I've searched everywhere I can think of, but no one has a tutorial on how to check it on this particular model. I was able to disassemble it without any trouble and I removed and inspected the power supply visually, but I'm hoping someone has advice on how to test it with a multimeter. I haven't been able to find any pinout or voltage information for it. Maybe the same unit is used in other models? Any help would be greatly appreciated.
Is dit een goede vraag?
Score 2
1 Opmerking
I also was wondering if i measure the veiwable area of the screen it's 21" the entire face is 24" so is this a 21" or a 24" Imac?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Just to the right of the RAM slots you will see the diagnostic LEDs. Tell us which ones are one. If just the first then you need to replace the power supply.
Here's the power supply: [gekoppeld product ontbreekt of is uitgeschakeld: IF169-000-1]
There's no teardown for this model yet but this guide should get you there: iMac Intel 17" Power Supply Replacement
Was dit antwoord nuttig?
Score 6
5 opmerkingen:
good answer +
door
I'm guessing if no LEDs are on, as is the case with mine, then it's *definitely* the power supply?
door
------------ Yes.
door
If you are replacing your power supply and don't already have a set of small torx drivers the [gekoppeld product ontbreekt of is uitgeschakeld: IF145-022-1] and [gekoppeld product ontbreekt of is uitgeschakeld: IF145-028-1] have the required torx bits, plus lots of other handy bits, and are a great deal compared to purchasing the individual drivers.
door
It was, in fact, the power supply. I followed a tutorial on this site to get the case opened and replace it. This is the correct power supply: [gekoppeld product ontbreekt of is uitgeschakeld: IF169-000-1]
door
If no lights are on can you say its the power supply or can you say its the power supply and/or the logic board? One would think testing the PS would be in good order before assuming its bad.
Score 1
Not for nothing, but my 24-inch mid 2007 iMac also went completely defunct in one power cycle. I actually brought it to an Apple Store where they replaced (according to the paperwork) power supply x2, backplane, and main logic board. They ended up returning it to me "no charge" and pulled the hard drive at my request.
I'm following up to ask you if you have had success with your repair. I'm leaning toward replacement but if this problem turned out to be something simple and mechanical like the power switch, it would be totally worth my time to tear it down and repair it.
1 Opmerking:
Thanks, JS. I'm feeling a little stumped, because Apple says they essentially replaced the entire guts of the iMac and it still was stone-cold dead. At some point you gotta ask, how could that be?
I'm glad your repair worked out!
door
Voeg je antwoord toe
JS24 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 9,341
