Ga door naar hoofdinhoud
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
523 Vragen Bekijk alle
Galaxy s4 camera fail
When I use the camera app it shows just a black screen and it says camera failed. Also I tried using a third party camera app and the front camera worked but the rear had green lines running across the screen. I went online and tried everything software wise to get it back to normal. I wiped the cache Portion and did a factory reset but still the same thing happened. Then I bought a new rear camera and still nothing. When I opened the third party camera the screen was black for the rear but worked in the front. Any other ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Could it be possible that the phone was in contact with water? Did you try cleaning the connector before reassembling the new camera part? Have you tried flashing another firmware?
Was dit antwoord nuttig?
1 Opmerking:
It may be possible I bought it from someone I know and I doubt it had had water damage. I don't think I did clean the connectors how should I try? And how do I flash another firmware
door
Voeg je antwoord toe
Gabriel Huerta zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 103
