cannot turn off /frozen!
HELP my bluetooth speakers have frozen and will not turn off,even when holding on/off switch down !
thanks in ad vance
Is dit een goede vraag?
Annuleer
The Zenbre Z3 is a high quality bluetooth speaker that allows you to play music on the go, and will immediately amplify your device.
thanks in ad vance
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkelHi,
According to the Ifixit troubleshooting guide for this speaker there should be a reset button near the 3.5mm Aux jack. As the online user manuals for the speaker do not mention this I'm not sure if this is correct. If it is have you tried it to see if it resets your speaker?
Zenbre SoundBank Z3 Troubleshooting
If it is not there or it is but it does nothing to fix your problem try the following:
Here is the Ifixit guide on how to remove/replace the battery.
Use it to disconnect the battery. Once disconnected hold the power button down to drain any residual power from the circuit (and potentially reset any corrupted firmware settings) then reconnect the battery and observe what happens when you switch it on. if it behaves normally test it out to see if it works properly. Ensure that you reconnect the battery connections the same way as it was. Take pictures of the connection before you first remove it.
Commentaar:
The reset is inside the audio jack at the back. Took like an hour to put that together lol. Dont take it appart just push button and done.
door dingo_707
It happened to me yesterday. My bluetooth speaker was frozen. So I let it for 10 hours until all its battery go down and then it turned off. After that I turn it on.
Rep: 1
Hi, your advice on the position of the reset switch at the bottom of the earphone jack socket was a master stroke, as it’s a bit longer than an Apple key, I used a paper clip, felt it click and switched the speaker off, switched the speaker on normally all works fine. Thank you.
Afgelopen 24 Uren: 38
Afgelopen 7 Dagen: 241
Afgelopen 30 Dagen: 1,169
Altijd: 18,007
You can try this, it worked for me. I just let me battery run all the way down. Recharge and that has seemingly fixed the problem.
door drunken_stumbles
Does anyone know how to reset a Gooodmans waterproof speak mine won’t turn off
door Morgan loves bts
