iPhone 6 front camera & ear speaker not working after screen replaceme
I recently replaced my iPhone 6 screen. Everything went smoothly for the most part. But the ear piece and front facing camera arnt working. The front mic (Siri can hear me) seems to work and the light proximity sensor works. But when I try to make a phone call I hear nothing. Front face camera freezes when you flip it around. Any one else have this problem?
Is dit een goede vraag?
8 opmerkingen
Sounds like front camera ribbon cable assembly needs to be replaced. I bet it was teared during screen replacement. You can double check if its plugged in if you want.
door Ben
I would agree with Ben, check it first but definitely a connection problem and with the fragility of some ribbon cables there is a good chance it was torn.
door Shelton Pinson
I checked the cable and it all looked intact.. Everything looked fine all of the copper on the earpiece looked ok. Would the front mic and proximity sensor work if it was tore?
door beckakeating
Inside that flex are multiple tiny traces. Its very possible that some of the traces are bad and some are good. Its very common to see some things on that flex work while others don't.
Its a very cheap and easy fix.
door Josh W
I faced the same. did you find any solution?
door bigshowtani
3 commentaren meer tonen
