Ga door naar hoofdinhoud
This device is a single-speed handheld router designed for woodworking. The original 690 router has been around since 1973, and since then minor improvements have been made.
3 Vragen Bekijk alle
Why does my router overheat after a short period of time?
After using the router for a prolonged period of time, the device begins to overheat, and feel hot.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
As outlined in the troubleshooting page for this device, you may be running at too high of a speed for the type of cut you're attempting to do. You could buy an adapter to allow you to change the speed such as this one http://www.harborfreight.com/router-spee... , or you could try making multiple shallow cuts so that your router doesn't have to work as hard. There are other possible causes of your problem though so I highly suggest visiting the troubleshooting page if you haven't all ready. There should be more solutions there.
Was dit antwoord nuttig?
Voeg je antwoord toe
Jaymes Ullrich zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 119
