Ga door naar hoofdinhoud
Microsoft's derde generatie Xbox game console, uitgegeven op 22 November 2013.
My port to the HDMI is broken in the Xbox
My question is I broke the inside HDMI port for TV output from my Xbox one. Is there any Alternative way to play my xbox some how? If not where can I get the parts to fix it and is there a guide on that?
Is dit een goede vraag?
Score 10
1 Opmerking
Can you not just take the HDMI in pass through port and desolated it and move it to the HDMI out port to make it work for now and fix hdmi in if you even care about it.
door
Voeg een opmerking toe
10 Antwoorden
Het nuttigste antwoord
If you search "Xbox One HDMI Port" on eBay, they have the part on there. There are also lots of videos on YouTube showing how to replace it.
I would warn you though, if you don't have experience in soldering, you could damage the main board trying to remove the old port. If you're not comfortable with the repair, it would be worth having an experienced tech do the soldering work for you.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
David is right. I fix lots of them where someone has tried to fix it but didn't know how. It ends up costing them a lot more because they tear the circuits traces off the motherboard.
I get that people like to fix stuff themselves but just be realistic with your abilities and tools.
door
If you get a hdmi to USB adapter can you not plug the hdmi cable in one of the Xbox’s usb slots?
Score 1
9 opmerkingen:
Yes I would like to know this. I am trying to find a solution to my sons hdmi issue on his 1 yr old xbox minecraft edition
door
Yes i would like to know trying to see if i should buy one
door
Anyone ever try it?
door
I bought one offline and it isn’t working for me at all
door
Any luck with this yet?
door
4 commentaren meer tonen
you should be able to get the parts here on I fix it but maybe radioshack or some other eletronuics bussiness
1 Opmerking:
ifixit does not sell those parts, nor does RadioShack or any other brick and mortar store that I know of. It's an online only part.
door
hdmi port replacement on xbox requires micro soldering and desoldering technique otherwise you will end up breaking the pads on logic board we have done many hdmi port replacement in our workshop for us it is easy if you live in new eland you can send it to us
1 Opmerking:
What is your workshop?
door
Get it from eBay like everyone said, or if you have a pc with windows ten, you can stream it directly to the pc and plug the controller to the pc or turn it on and play without it being plugged up to the TV
1 Opmerking:
Please elaborate on this .... I have the same problem
door
Yes I have the same broken hdmi slot
Can you not just take the HDMI IN pass through port and desolder it and move it to the HDMI OUT port to make it work for now and fix hdmi in if you even care about it.
i really wanted to get the Fortnite battle pass so iam sad
How can I play my Xbox one x if my HDMI is broken on my tv
connect a controller to your phone and do remote play through the xbox app
Score -1
Voeg je antwoord toe
Ryan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 148
Altijd: 70,758
