Steve, when it quits when hot, that would be a good time to test the fuel pump to see if it is faulty by pulling the line off carb. and turning engine over to see if it is indeed pumping fuel. Remove plug wires and make sure leads will not spark in vicinity of fuel, direct fuel hose into clean container and turn engine over 10-20 sec's. observe weather you are getting fuel. If pump does seem to be working, hook all back up.
Now with fuel that was pumped into the container you are going to do another check, remove air filter assy. pour about a 1/4 ounce of gas in carb. throat, start tractor. If it fires up your problem most likely is a dirty carburetor needing cleaned/rebuild. If it does not fire up, I would check for good spark/compression/valve clearance, safety switches faulty,oil sensor faulty if equipped, etc. Check the attached trouble shooting links,instruction and guides,manual. Good luck.
http://www.kohlerengines.com/maintenance...
http://www.repairclinic.com/RepairHelp/H...
http://www.kohlerengines.com/manuals/lan...
4 opmerkingen
This question was migrated from http://meta.ifixit.com/Answers.
door iRobot
What engine? Fuel injection or carburetor?
door cayte03
Yeah bud, we need JUST a bit more info. Year, make, model and size engine would be very helpful. Thanks.
door Mark Burden
Any chance you can identify the engine a bit better. Got a number for it.?
door oldturkey03
