Ga door naar hoofdinhoud
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 Vragen Bekijk alle
What is the correct drive belt number?
I have a murray 2000 hydrostatic drive riding mower and I need to know what is the correct drive belt number?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
betty, go to the attached link and select your model #, to see parts list where you will be able to get the correct drive belt. Good luck.
http://www.ereplacementparts.com/murray-...
Was dit antwoord nuttig?
Score 1
You need to get the model number of your lawnmower (the body, not the engine). Look up the parts diagram on a site like ereplacementparts.com It will tell you the parts number. FYI - there are often several numbers for the same parts, depending on who the manufacturer is (OEM or aftermarket)
Score 1
Voeg je antwoord toe
bettyebrad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 20
Altijd: 1,525
