Ga door naar hoofdinhoud
Model number MFC270EN was released in 2012 and uses Android 4.0.
My LexiBook Junior tablet won't turn on
My Lexibook Junior tablet is over 3 years old and I've had it plugged in for a really long time, but it won't turn on. The charging cord looks fine and I haven't abused it, so why won't it power on?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check if the charging port in the tablet is damaged or if the charger will not fit into the charging port. Check for corrosion on battery. Depending on how old the battery, it might be bad and need replacing. Look for damaged wires within internal circuitry. Also, Corrosion on motherboard may lead to your tablet failing to turn on. In this case, return it to the vendor. For more information check out the troubleshooting page.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Rachel Klesius zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 889
