Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Tablet van 0,622 kg (1,4 lb) met een scherm van 10,8 inch en een uitklapbare standaard met 3 standen, op 5 mei 2015 uitgebracht door Microsoft. Modelnummer: 1645.
LCD Connector is damaged, help!
Hey all,
The connector where the LCD plugs in on my surface 3 was damaged during a screen replacement. The issue is I dont know what the part is called or where to purchase a new one.
Please help me
Update (10/06/2016)
Afbeelding
This is the connector in question. This is on the main logic board and the LCD flex plugs into it. The black piece that clamps down on the flex is gone and there is a missing pin.
Is dit een goede vraag?
4 opmerkingen
Is it on the LCD or the logic board?
door Deel
The connector on the board was damaged in case that wasnt clear.
door Deel
[image|907316]
door Deel
Mike check the update. Looks to be a internal 35 pin logic board LCD connector.
door Deel
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
Mike, if you can post a picture of damaged connector, it would be a big help to ifixit , I believe the connector is the mother board ribbon connector. Check the attached link and see if it is the motherboard connector, Good luck.
Microsoft Surface 3 Display vervangen
Update (10/06/2016)
Mike, Looks to be a internal 35 pin logic board LCD connector. Hope the link is what you want, you can also try a search yourself for (35 pin lcd connector)
https://www.aliexpress.com/item-img/20-P...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Posted a picture below showing the connector.
door Deel
Afbeelding
Afbeelding
Mine too damaged, are you sure it's 35 pin connector at AliExpress
I don’t think the above connector from Aliexpress is correct. Looking into it it seems to use the same connector that is on the Samsung Galaxy Note 4 2014. It is actually a 70 pin connector not 35 because there are pins on both sides. You might be able to buy a replacement off eBay or Aliexpress.
Below is the link to the connector on Aliexpress.
FPC Connector From Aliexpress
Did anyone ever get anywhere with this??
Voeg je antwoord toe
Mike Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 2,537
