Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Model A1318 / 32 or 64 GB capacity
395 Vragen Bekijk alle
Broken screen - touch function didn't work before or after repair
Hi,
I'm repairing an iPod 3rd Gen that came to me with a broken screen. The touch aspect didn't work.
After replacing the screen/digitizer, the touch aspect still doesn't work. I've double and triple-checked the cable and am pretty sure I have it in right.
I have also tried hard resetting, restoring, multiple times.
Any help?
Thanks in advance.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Commentaar:
I just gave up... nothing I could find. I assume the drop damaged the logic board.
door
Voeg een opmerking toe
LCD iPhone-scherm fixkits
De goedkope optie, ondersteund door onze levenslange garantie.
Koop kits
Bespaar op reparatiekosten, niet op kwaliteit.
Koop kits
1 Antwoord
Gekozen oplossing
If the touch screen doesn't work, then either the digitizer is broken, or the connection is bad, or the logic board is broken.
If you've already tried replacing the digitizer, then disconnect the cable and examine the connector on the logic board with magnification, and see if you see anything you can fix. If not, then you'll have to replace the logic board.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
spacec0w zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,113
