Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Will my Verizon (CDMA) iPhone 6 work in GSM-only countries?
Does CDMA work with GSM towers?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Verizon is factory unlocked for GSM carriers. You should be able to use it with a GSM SIM outside the States.
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
It will if the phone is network unlocked.
Better check up with Verizon and get them to network unlock it for you.
Score 2
Question 1 ) Yes. it will work. also you can check whether your iPhone 6 is carrier unlocked or not, contact Verizon and verify before roaming.
Question 2) Different technologies, BTS/Node B depends on the network operator. :-)
Score 2
Voeg je antwoord toe
Andy Salad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 216
