Ga door naar hoofdinhoud
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Vragen Bekijk alle
MacBook only powers on with adaptor, doesn't detect new or old battery
So I've been fixing a macbook I got cheap on gumtree that was being sold as faulty. I needed to replace the HDD, fan,LCD and the keyboard and it turns on and everthing works fine except for the battery.
So here's what I've learned from troubleshooting so far
  • Only turns on and stays on only when plugged in
  • Doesn't detect original battery or new battery
  • Tried resetting PRAM, SMC
Any information would be helpful
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi
I had exactly the same problem recently with a Mid 2012 13" Macbook Pro and tried all the steps you mentioned.
Turned out that I had a broken battery sensor (flat connector on the bottom right hand side of the logic board which is connected to the button on the right hand side that shows battery power level)
After disconnecting this connector and doing (yet another) PRAM and SMC reset, the Macbook started working. Will be ordering another battery indicator cable but for now leaving it unplugged. Charging light went orange and it detected and charged the battery right up to 100% and has been sitting running on battery power for hours now with the battery indicator cable disconnected!
Also another thing to make sure is that you have the latest SMC Update installed , as SMC version 1.5 did resolve battery issues. (And SMC v1.8 on the 2012 model)
https://support.apple.com/kb/DL1474?loca...
Was dit antwoord nuttig?
Score 1
Thanks Alex
It seems that it was the battery indicator was faulty, after unplugging and resetting the PRAM and SMC the power indicator on the charger changed to Orange, and the battery is now being detected by the system.
I've ordered a new charge indicator.
Thanks heaps again!
Score 1
1 Opmerking:
You're very welcome! :) Glad to hear you got it fixed
door
Voeg je antwoord toe
Carl J zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 66
