Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Vragen Bekijk alle
Dont Know why has white vertical line on the screen
i'm no idea how this sad happen .I never dropped my phone or into water. Today when i'm reading novel the white line suddenly popup slowly. After that i try restart the line still leaving....why ....
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
seng, take iphone apart and try reseating the cables, this may fix the issue. Check the attached links,instruction and guides on how to access cables , Good luck.
https://www.youtube.com/watch?v=vObeEEWF...
https://www.youtube.com/watch?v=oMQZv7bf...
Was dit antwoord nuttig?
Score 3
1 Opmerking:
thank for your solution, i try unplug the connector of LCD and cleaning the socket but the problem still happening. so i try to replacement the LCD and all problem is solved. So i think the ribbon of LCD is already damaged. However thank for your reply XD
door
It's usually damaged ribbons or the screen connectors aren't pushed on correctly. The May need cleaning too.
Score 1
Voeg je antwoord toe
sengweiit97 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,040
