Ga door naar hoofdinhoud
Reparatiehandleidingen en demontage-informatie voor Android-telefoons in alle vormen, maten en kleuren. Vind hier alles wat je nodig hebt om je eigen telefoon te kunnen repareren.
33477 Vragen Bekijk alle
Where are the solenoids located on my 2001 honda accord?
Recently p0780 code popped up i thought it needed a tranmission oil exchange cause the oil was not good . when i drive my car it jerks and it wont pass a certain number . so im figuring its the trans shift solenoid . but idk where its located on my 2001 honda accoord ex v6 . . please help !!!
Is dit een goede vraag?
Score 4
2 opmerkingen
Where are the shift Illinois on a 2003 Honda Civic with the VTEC motor
door
I have a 2003 honda civic ex coupe which was having problems shifting after the first gear . What could be the problem .
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Jacob, Shift solenoids B,C are located on the outside of the transmission case see 2nd link for testing info. You should change your trans. fluid if it looks poor. as it could be the problem. P0780 indicates a shift solenoid malfunction but it could possibly be caused by, low transmission fluid level, dirty transmission fluid, faulty shifting solenoid valve, shifting solenoid valve harness is open or shorted, shifting solenoid valve circuit bad electrical connection. Check the attached links,instruction and guides, Good luck.
https://www.youtube.com/watch?v=kp064kVi...
http://troubleshootmyvehicle.com/honda/2...
Was dit antwoord nuttig?
Score 5
It is in the valve body of the transmission behind the pan. Better get a professional to change it.
Score 4
1 Opmerking:
But they are not inside on a honda. They all bolt on the outside and are rather easy to change. The filter is inside the trans.
door
Actually the first answer was right. The shift solenoids on Honda transmissions are on the outside. But if the car does not want to shift first thing is the check the fluid color, odor, and level. If it's black or brown and smells burnt that's not good and it could possibly be something internal screwing up the solenoid. The cheapest easiest way to fix the solenoid would be a junk yard. A Trans shop will charge you a lot and usually will want to change the whole tranny and not just 1 part.
Score 3
1 Opmerking:
What about online to get solenoid
door
My 1996 Honda accord won't go in drive
2 opmerkingen:
How many solenoids does a 2001 honda accord have.
door
2 brother on to n bottom of transmission
door
Voeg je antwoord toe
Jacob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 136
Altijd: 40,429
