Ga door naar hoofdinhoud
A portable e-book reader developed by Amazon. Repair is straightforward and requires only prying tools and screwdrivers.
55 Vragen Bekijk alle
Charging port stopped working.
charging port stopped working. I cannot re-charge my kindle paperwhite. Has anyone had problem like this, and what can be done?
Thank you,
Sandra
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sandra, sounds like you may have a loose USB port. Charge port is soldered to a circuit board inside the Kindle that allows battery to charge. If the soldered connection breaks, the battery no longer charges. If you google your problem you will see there was a problem with Kindles charge ports.
Small computer/cell phone shops can make repair/replace charge port, get an estimate, just a guess $30-$40.00. Good luck.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
sandra zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 710
