What did I fry on my logic board?
So. I was changing out my LCD in my MBA when I ran into a problem. After connecting the LCD connector and the LED ribbon, the display would turn on but the LEDs would not. I was almost positive that the LED ribbon was installed correctly, but after hours of scouring the internet, I think I have come to the conclusion that it was actually backwards. The problem is, I can't test that now because the LCD doesn't work anymore. And I think it doesn't work anymore because when inspecting the LCD connector using the "pro" tweezers I bought, I happen to notice a tiny bit of smoke coming from the connector. At first, the computer wouldn't even turn on, but then I connected the LCD and it the computer turned on. At that time I didn't think to see if the LCD was working too. I assumed I was good. By the time I figured out to install the LED ribbon in the other way, it was too late and now presumably something is fried. My question is, how do I figure out what is fried? The whole logical board? Just the LCD controller? I don't know where to start. Any help is appreciated. Thanks.
EDIT: Below is images of the board.
[image|904917
[image|904912
Suspected Damage:
Is dit een goede vraag?
2 opmerkingen
photogwa start by taking it apart, removing the logicboard and checking for obvious damage. Post some images of your board with your question. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that. It will allow us to see what you see. Use these guides MacBook Air 13" Mid 2011 to work on your computer.
door oldturkey03
Thanks for the guidance. I realized after I went to open the bottom that I don't have a small enough screwdriver. So I am waiting on that to arrive. I will post images once I get it open.
door photogwa
