Ga door naar hoofdinhoud
Fix Your Stuff
Right to Repair
Parts & Tools
The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3965 Vragen Bekijk alle
Touchscreen won't respond after liquid damage
Hello,
My iPhone 5S fell into the water from the touch screen does not respond.
I switch the screen but the problem is not solved.
Then I clean up the motherboard with the ultrasonic cleaner in a bath of isopropanol but, it did not work.
I think change the chip screen, do you think it will solve the problem ?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It looks like a Touch IC failure. You should get the chip replaced. Its not a DIY job.
Was dit antwoord nuttig?
Voeg je antwoord toe
Anthony Fassler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 54
