Ga door naar hoofdinhoud
Open the HP 15ac137cl Case
How do I remove the back cover of the HP 15ac13cl so that I can replace the hard drive?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I thought I had marked this issues as solved. Thank you so much to everyone that helped!! There were two hidden screws underneath the rubber pads near the monitor's hinge. Once they were removed, it came right open.
Was dit antwoord nuttig?
Het nuttigste antwoord
HP has a link to their repair manual PDF here:
http://h10032.www1.hp.com/ctg/Manual/c04...
Looks like there's a Service Door that may help.
Score 1
1 Opmerking:
Thank you! I'll read a little deeper since this particular model doesn't have any service doors or access panels to anything. There might be a clue in there somewhere tho!
door
Voeg je antwoord toe
Sandee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 213
