Ga door naar hoofdinhoud
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 Vragen Bekijk alle
still not starting gas is new
Gas getting to carburetor but still not starting gas is new and plugs and oil
Update (09/11/2016)
Murray select riding mower
Update (09/11/2016)
Dry Murray select model 42A707-2653-E1 yes I have spark and turns over put gas in carburetor it starts and dies out
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Scott Irwin "put gas in carburetor it starts and dies out" sounds like a stuck needle valve or bad fuel solenoid. Take the carb off, clean it and check the float level and needle valve. Here is the parts manual for your engine Briggs & Stratton 42707. I also attached the service manual for the carburetion of your engine B&S Carburetion Carburetor overhaul kits are available at places like this and many others.
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Scott, trouble shooting small engine no start links below. Check the attached links,instruction and guides, Good luck
https://www.briggsandstratton.com/na/en_...
http://homeguides.sfgate.com/riding-lawn...
http://www.mtdparts.com/equipment/mtdpar...
Score 2
Voeg je antwoord toe
Scott Irwin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 244
