Ga door naar hoofdinhoud
Repair guides and support for tablets produced by Lenovo including the ThinkPad tablet line.
468 Vragen Bekijk alle
lenovo yoga tablet 2 suddenly won't charge or open
Hello! I got my Lenovo tablet 2-1050F ( Mfg Date: 2014-12-23) in January of 2015 , I wasn't frequently getting on my tablet more than once every 3 day and sometimes I decide to use it and I find that the battery is empty, while there were no applications left open that may cause the battery discharge. Today and after three days of non-use the Tablet... I found the battery empty, I plugged in the original charger but nothing worked even the light around the Bush button key.
I searched the Internet looking for a solution and I have followed the steps showed below but it has completely failed
1. Plug the power adapter into the Tablet
2. With the adapter plugged in, Hold down the power button for 20 seconds
3. Disconnect the power adapter from the Tablet and press the power button for 20 seconds.
4. Reconnect the power adapter and turn on the Tablet. It should power up just fine.
Please any other help rendered shall be of high importance
Is dit een goede vraag?
Score 30
22 opmerkingen
I had the same problem. Followed just step 3 and 4 which made the tablet turned on. It showed 73% battery charge left on the tablet and was able to proceed to login. So it worked for me.
door
My Yoga 2 (2014) was on standby overnight and crashed. Zero battery all next day, refused to charge, did power on power off, ran check up, ect, no good. Now just did steps 3 and 4 above and to my surprise it's charging. Can see it's working by power monitor plus wall power pack is heating up per normal. I suspect battery voltage was abnormally low and charger was confused but what does holding power button for 20 sec do?
door
I have a Yoga Tablet SG3 Black, I tried this, and I know it's not a Yoga Tablet 3, but it just showed this code, and I don't know what to do, please help.
door
When it occurred again I on-line chatted with Lenovo and they had me update some drivers and BIOS - great now.
door
Hello, i have a problem with my lenovo yoga tab8 , its reeboot when i whant to charge or when i connect to the pc , it dont stop, its reboot and reboot, on the screen its writen tool dl image file! and i cant connect with my pc to solve with sp flash , please help ....
door
17 commentaren meer tonen
Voeg een opmerking toe
19 Antwoorden
Het nuttigste antwoord
I had to open the tablet, disconnect the dc power jack connector and then reconnect it. After doing this, then you should be able to plug the tablet back in to power and it should start up.
On my tablet, there was a third hidden screw under the opposite side of the label that I peeled to find the first hidden screw. Be sure that you locate *all* the screws before trying to pry the case open...
Was dit antwoord nuttig?
Score 8
8 opmerkingen:
works perfectly. I was sooo close to binning this tablet as junk. Thanks
door
Only had to do the first 2 or 3 steps on the guide. Took more time to get the case off. Thanks again
door
Open the tablet isn't difficult but how difficult is to disconnect through dc power jack connector
door
Worked for me too, exactly as described in the original post. Thanks for saving my tab!
door
Work well for me. Thank you.
door
3 commentaren meer tonen
Score 5
4 opmerkingen:
Litraly signed u for rhis page to thank you i was scared it was lost . Followed ur steps and booyaah! Thank you so much
door
Have followed all 4 steps but still nothing. Tablet is totally dead
door
@Chris Fifield, try starting your own question, you will get more help that way
door
it worked nice thanks
door
yours solution does not works (In my opinion).
I have to dismount back cover and disconnect PRIMARY (rechargable) battery. After it - shortcutting RECOVERY battery (small button battery - connected thru blue and red wire) for erase recovered memory.
Then connect primary battery.
After this procedure table has been repaired and normally operated. Just only date and time was reseted.
Ciao,
Honza
Score 1
1 Opmerking:
Do i have to disconnect the primary battery which is difficult to access, why just short circuit the RTC battery ?
door
Its Fine, dont worry.
Put the tab in charge for like 3 days, do not touch it. Then try to power it on, if it dosent still start [its a high possibility that it will start].
Then the only other option is doing factory reset[I dont recommend it].
Score 1
2 opmerkingen:
I find using the genuine Lenovo products leads chargers replaced twice just as quarantee expires Lenovo Tab2 10/30 lost life .I believe battery issue might be he is lifeless too needs replacing .Left it charging went up to 30% soon went down to nil by leaving alone overnight .No charging happening might have to go hospital services department for check over and replacement recommended be vital .I need of bringing life back into him/she .Any idea how much battery cost anything else in health record I have ongoing private health insurance in place .
door
Go to Lenovo website there you will find Lenovo listed menu of all answers and questions also chat talk to all issues to topics found it very valuable site .Not just Lenovo click in on most branded devices find solutions even buying eccessories .Don't recommend charging devices over night nor over 3day period not ideal 3days is definitely a no/no also damage your devices .Leave for a few hours then check if battery is charging leave 5/6hrs don't need a full charge 80%is best scale as it will keep devices in good working order for much longer
door
My tablet (Lenovo Tab 10.1) started playing up charging, i had to put the charging cable at a angle for it to charge, or put something under the cable to slant it a bit for it to charge. It got worse as weeks went on and wouldn’t charge at all. I tried the stuff people said with leaving it on charge for 3 days etc, nothing. Tried 3 different cables and chargers and nothing. I got 2 of the same tablets and all the chargers worked fine with my other tablet. Then i found my Genuine Lenovo plug & charger which i used for my FireStick and thought I’d try that. And it worked!! All the years of knock off chargers must take its toll on the tablet, My phone sometimes does that, needs the Genuine cable. I hope this works for other people. Saved me money, was going to buy a new one.
Score 1
1 Opmerking:
Bingo. After going crazy and ready to buy new computer it just needed proper cable to charge. As soon as I connected proper cable it began charging.
door
My Yoga would run on power but not charge at first intermittently then permanently. I spoke to Lenovo help line and they had me update some drivers and BIOS. Been fine for one year since.
Score 1
NONE OF THE TIPS WORK
My tablet is Lenovo yoga tab 2 1050f . I have tried all the solutions listed above but none of them seem to work for me. my tablet was given to me by school and now it has this problem. wont charge and wont turn on. i also tried opening the back and removing the primary battery but I don't know how to take the primary battery out. please let me know a solution.
Thankyou
1 Opmerking:
Morning any name go to UTube in search add device and video you wish to watch this is where I found how to open the back of Lenovo and other brands Seems Lenovo comes up easy Tab taken off the back panel replacing battery seems like small battery in its position
door
I had this problem and it fixed it. My laptop is now charging. What did I just do? Reset it?
1 Opmerking:
Mine the same can't reset no charging happening so I believe battery issue
door
Check hdmi connector.. mine has an obvious bent pin and burn mark. I believe that this is the cause as battery voltage recovered when disconnected.
Its possible that disconnecting the 5v to the socket might be a workaround but need to investigate further.
Incidentally this is a weak point on many devices and backfeeding can cause serious damage.
As I have this problem plus following guideline information on many sights still Lenovo 2 tab was completely dead having bought it mid 2015 .It is in the repair stores due back within next few days .I can report back here the electrical engineer report might be of some help to you people .I have a monthly general domestic repair and support insurance I took out when purchasing Lenovo I'm glad I did as it does cover this device for damage no matter how caused plus eccessaries if unrepairable I get a new one or voucher to redeem .Will report back soon hope I can guide you what might be the issue .My gut feeling is dead battery's or jack point damage I think that's what you call it, or gateway charging unit .
I have a Lenovo yago A12 and I just bought a Lenovo adapter still not charging 0% but it comes on tryed the 20sec still not charging can you help me please
Thanks I don't know I tryed everything who can I talk to
I’ll say it again….When it occurred again I on-line chatted with Lenovo and they had me update some drivers and BIOS - great now.
1 Opmerking:
How do you update the drivers and BIOS.....and which drivers? Need help ASAP. Thanks
door
Kinda hard when the computer won't power up
Yes, your right but the message is use another device to get an on line chat going with Lenovo - have your Yoga serial number etc ready.
Hi I have got the same problem,I do not no if it's the battery is dead,there is nothing wrong with the charger,I got the casing open, I can take out the battery,but it has got a copper power censhon to the battery,I do not what to tamper with it, could you explain what can I do,thanks.
2 opmerkingen:
Hi I got a Lenovo tablet,but it will not charge up,I took of the casting of the back,,there is nothing wrong with the charger because it charge the other tablet I can take out the battery out ,but it is cenicet to a copper wire,I do not what to touch it,can you explain for what can I do, are would it better to by a new one,thanks.
door
Hi did you got my message,if you do not mind could you reply, thank.
door
This 20 seconds holding the power button thing worked perfectly. My tablet turned on in about 16 seconds. It is working and charging just fine now, like nothing happened. Weird. But thanks for the tip!
1 Opmerking:
Hi Melanie,have you try to go to factory reset settings,what do you mean,like nothing happened did you your icons on the home screen,thanks,can you email if it has worked,ok
door
My laptop suddenly not open battery is good but not saw power in and not open
On my Lenovo X1 Extreme laptop, I had a similar problem. I was able to restart it by resetting it. I found a pinhole on the back (bottom) of the laptop, used a thin wire (an unbent paperclip or something similar), inserted it into the pinhole, and pressed down for about 5 or 10 seconds ("long" press). The laptop was then able to power on. I don't know if that will work for your laptop, but it might be worth a try.
Voeg je antwoord toe
Shiko zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 218
Altijd: 80,667
