Ga door naar hoofdinhoud
Daisy Model 10 Carbine 400 shot BB repeating air rifle. Maximum velocity: 350 FPS. Maximum shooting distance: 195 yards. Lever cocking action. .177 cal. BBs. Part No. 300664-000
BB gun will $!^& but not fire,doesn't seem to compress spring
Daisy Red Ryder B.B gun model 1938B
so my son,daughter and i were enjoy some pinking when my daughter says the bb gun wont fire. put it on safe and took if from her, I manually cocked the lever but if felt like there was no resistance, took gun off safe aimed and attempted to fire, nothing happened, tried the safety a few times to ensure it wasn't stuck.. that isn't the problem..
Is dit een goede vraag?
Score 4
4 opmerkingen
apparently there is some sort of language filter here, I will assume you guys/gals know what I am trying to say about the condition of the gun.
door
It won't pump up ;-)
door
sure, there is another word but..
door
i,m not involved in any of this latest bb s--- ,m eighty yrs old and still like shotting cans and targets
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
bpjefferson365 and @mayer, my thought is more related to the plunger and the lever not connecting. If the lever does not connect with the plunger then there will be no resistance. Even if the spring would be broken, it would still have some resistance since it can not move anywhere. See if this diagram will help a bit. Here is a really good tutorial, even so the model is different. It should still apply to your Daisy as well.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
It may be c*cked now.
door
Nah, the mechanism is not working for that
door
I have a old flip down barrel BB gun and it's missing the little round thing that connects to the fireing pin so it does flip back down
door
Try checking out the firing mechanism : Daisy Model 10 Carbine Firing Mechanism Replacement
Score 2
Voeg je antwoord toe
bpjefferson365 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 31,377
