Ga door naar hoofdinhoud
A sanitary disposal device for human waste. No plumber necessary! Fixing a toilet is more straightforward than many people think.
24 Vragen Bekijk alle
Consistent dripping sound coming from tank
There is a consistent dripping sound coming from the tank of my toilet. What could it be?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
Over time the flapper - which is soft and supple new - becomes dry and hard. Replacing the flapper will normally fix a dripping issue, and it's about a 5 buck repair.
Was dit antwoord nuttig?
Score 3
Het nuttigste antwoord
Flap which stops water to come in side has been wastage.It would be change.
Score 6
1 Opmerking:
Really a score of 8 on this answer! Really amazing and total BS. Having your buddies vote a poor answer up like this risks getting you banned from the site.
@kaykay
door
Here's the guide on replacing the flapper: Toilet Flapper Replacement
Score 5
Try putting a new tank kit in it?
1 Opmerking:
It may be time to replace the whole kit soon anyway. As there is no visible water leaking from the tank and no overflows ever, I just wonder what it might be.
door
It' cause of a bad flapper, it can't hold the in the tank and the water is dripping from the tank. You should replace the toilet flapper asap.
Voeg je antwoord toe
Max Fishman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 17,509
