Ga door naar hoofdinhoud
Repair and disassembly guides for Sony DVD players.
65 Vragen Bekijk alle
dvd won't play and door will not open
dvd doesn't play and door will not open to remove disk
Is dit een goede vraag?
Score 8
13 opmerkingen
Hey my DVD won't play movies . how can I fix it? My DVD is a sony brand blue ray player
door
Hi @sebrina mikul
What happens when you insert the disc?
Do you get an error message of any kind?
Can you hear the disc spin up?
If the disc spins up have you tried cleaning the laser lens (example only) in the disc player?
What have you tried?
What is the model number of the player?
door
When I put my disc in it will spin up then stop. I tried to take it apart. But I didn't
door
And it has nothing to Do with the disc it's self. Its the blue ray player
door
Hi @sebrina mikul,
Try cleaning the laser lens using a lens cleaning disc (example shown in link I posted). This is a non invasive method to clean the lens. A dirty lens prevents the disc from being 'read'.
door
8 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi,
What is the model number of your DVD player?
You can try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
If this doesn't work and since you do not state the model number of your DVD player, try the following:
Simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Was dit antwoord nuttig?
Score 6
6 opmerkingen:
I was able to get the door open and remove the dvd, but when I inserted a blank to record, it won't format. Just get loading message that doesn't go away. Dvd gets stuck again.
door
Model is a sony vx511 vhs dvd combo.
door
Hi @mowens5039,
Can you play a pre recorded DVD OK?
Have you tried a different DVD disc?
Have you tried cleaning the DVD laser pickup lens using a commercially available lens cleaning kit?
door
I have a sony blu ray disc player BDP-BX2... The tray will not open & I have tried the reset & unlock procedures, yet it will not open... There is no disc in the tray
door
My new Sony dvd buttons are not working.
door
1 commentaar meer tonen
Hi @jrcofie ,
There may be a disc still in the tray and is stuck there.
Try the following:
Turn off the power. There should be a small hole near the DVD player opening bezel (flap that opens when tray comes out). Use a straightened paper clip and insert it gently into the hole. It should cause the tray to come out just far enough so that you can grab it and gently pull it further out to see if there is anything on the tray.
Score 2
4 opmerkingen:
Failed at step one. Player will not turn off pressed front power button and nothing happens. Held button, nothing, still on.
door
Help I have a LSB03-D dvd Soundbar player that will not accept a dvd it keeps siting it out like there’s already one in it but there isn’t how can I make this work
door
Hi @mycrazydog2
Has it worked OK before?
Just verifying that you are pressing the "up arrow button with the line under it" either on the player or on the remote to insert the disc and to remove the disc from the player?
Here's the user guide for the player.
On p.7 "Front Panel In and Out of the disk" section and on p.8 "Remote Control" section, the button can be seen for both the player and the remote control
door
Many thanks Jayeff! My Panasonic TV /DVD combo had a disc stuck in the tray for over a year and your great tip about sticking a straightened paper clip in the little hole worked like a charm, (actually I used a safety pin because my paper clips were too thick to fit into the tiny hole). I am so happy that it works! Bless you for sharing your knowledge with the masses.
door
A sharp tap on the top around 2 thirds back when you hear the tray trying to open and this will cause the tray to open,not realy a fix but it works on 2 DVP-SR150 players
1 Opmerking:
Model DAV-TZ145
door
Voeg je antwoord toe
Mike Tartaglia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 75
Afgelopen 30 dagen: 326
Altijd: 80,899
